Hope everyone is well,
I am running into a wall here. I have generated a StartOSUI Tor URL and I’d like to access the server from anywhere in the world or any other wifi / data. When I go to tor on different devices I put the url in and it just loads forever until it times out.
Setup: StartOS 0.4.0 on an x86 mini PC (Beelink). Tor 0.4.9.12 installed from the marketplace.
Goal: reach the StartOS admin UI over Tor from outside my LAN.
What I did
- Installed the Tor service from the marketplace, started it, confirmed healthy.
- Added an onion service to
start-os/admin/admin-ui, SSL off, no vanity private key. - Tested the .onion in Tor Browser from off-LAN (phone on cell data, and desktop).
Result: times out every time. Tor Browser parses and resolves the address fine — the error is “The connection has timed out”, not a DNS or malformed-address failure — so nothing is answering on it.
Already ruled out
- Tor bootstraps to 100% within seconds on every restart. Consensus healthy, exit nodes present.
- Other onion sites (the DuckDuckGo onion) load fine from the same client, so my Tor client and network are not the problem.
- Ran Reset Tor Connection. No change.
- Relay mode had been enabled at one point; turned it off and confirmed the “configured as a relay and a hidden service” warning no longer appears.
- Fully uninstalled Tor, reinstalled clean, created a single fresh onion and nothing else. Same result.
- Tested off-LAN, not from the same network as the server.
What the logs show
- Every time an onion is created or the config reloads:
Sep 12 20:50:18.000 [notice] Found secret key but not /var/lib/tor/hidden_services/start-os/admin/hs_0//hs_ed25519_public_key. Regenerating.
Note the doubled slash in hs_0//hs_ed25519_public_key. The same line appeared for an Ollama onion at /var/lib/tor/hidden_services/ollama/api-multi/hs_0//hs_ed25519_public_key.
No descriptor upload or HSDir publish entries anywhere in ~10,000 lines of logs spanning about three weeks.
Heartbeat lines read:
Our onion services received 0 v3 INTRODUCE2 cells and attempted to launch 0 rendezvous circuits.
Question: is that path with the doubled slash expected? It looks like the public key file never lands where Tor expects it and the service is never published. Anything else I should check, or is this a bug?
If anyone has any ideas on how I can access my server I’d greatly appreciate it.
-Andrew
