Dojo Syncing 99% - UI fails to open
Sometimes Dojo opens fine but a lot of the times it doesn’t open at all. The dashboard says that it’s still syncing with electrs or fulcrum at 99% and it stays like that for hours at a time. I tried fulcrum when I found this issue and it’s still happening. The problem survives a rebuild
System resources could be a factor. Things struggling to stay in sync typically means not enough RAM or slow drives. Anyone running Electrs AND Fulcrum with Bitcoin is definitely going to need a quite powerful setup. Certainly a minimum of 16GB RAM and a fast SSD.
