I just moved and setup a new network. I can find the start9 on the netowkr and see that it says storage drive not found and StartOS disk not found.
The SSD drive seems fine. I kept it with me during the move along with the server and cables. It is powered on. Nothing I can see is loose. Its in the blue port.
Possible solutions:
Insert your startOS storage and click restart
My start9 is a 2021 device. I dont think I have the option to do internal drive. When the upgrade to 3.0 i believe aroun 2022 or 2023 was happening i had to get an external ssd to upgrade versions.
You’re saying I can connect the SSD drive directly to my Mac and see if the data can be read so that we can rule out a corruption at the drive level?
Hi @Hadrian, plugging the SSD into the Mac is a good step, but it won’t fully confirm the data is fine. StartOS encrypts the drive (LUKS), so the Mac can’t mount or read the filesystem itself. What it can tell you:
Drive doesn’t show up at all in Disk Utility → enclosure/cable/port problem, not StartOS or corruption.
Drive shows up but as an unrecognized/foreign partition → that’s expected (it’s the encrypted volume) and actually good news, it means the drive and enclosure are electrically fine. Don’t try to initialize or format it.
If it shows up, the fault is more likely a connection issue back on the server side. Try a different USB port and cable on the server before anything else.
Hold off on “repair drive” until after this check.
