Problem with Datum and Bitaxe resets peer and StartOS v 0.4.0.1
Error on Bitaxe logs:
192.168.x.y:23334 (errno 104: Connection reset by peer). I don’t see any login attempts or errors in the Datum logs.
Datum v. 0.4.1:15
Any ideas?
***UPDATE
I’ve check port access to :23334 ie. nc: connect to 192.168.x.y port 23334 (tcp) failed: Connection refused
***UPDATE 2
I’ve ssh’d into the Start9 machine and issued a netstat -ano | grep 23334 and no port open.
I installed a standalone version of Datum on a VM on the same network I have no problem with the miner attaching to it on port 23334. And I am able to RCP to the bitcoin node on the Start9 machine no problem.
I tried to rebuild the service but the issue persists.
Have the exact same issue. From what I learned, startd completely fails to open port 23334 – this is why it doesn’t even show up as listening port via ssh. I also rebuilt, uninstalled / reinstalled and there is no 23334 to use as indicated in the datum interface. I also checked to make sure there weren’t other hidden ports available for datum and there were not. My s9 install (0.4.0.1) is completely clean and from scratch as well (not an upgrade).
I put a bug report at github. However, I don’t know what anomaly it is that the “others” are able to use it. Well one thing is with my Start9 instance this is a new install of Datum after I upgraded from v0.3.5.1 to v0.4.0.1.
Not some app that was carried over from the upgrade.
Like you it’s a new install of the Datum app. Go over to GitHub if you get a chance and put in a bug report. Well at least now there are two of us that have the same issue with no 23334 port open.
I think what might confuse you is that there is no port 23334 open/visible at the start9 host level, but the package containers themselves can show the port is listening/connected. On my start9 host, the working Datum container can see the following ports (hex ports converted to decimal so we can pick out 23334 etc)
start9@p-c:~$ start-cli package attach datum cat /proc/net/tcp* | perl -pe 'while (/:(\X\X\X\X) /) { $d=sprintf("%5d",hex $1); s/:$1 /:$d /}'
sl  local_address rem_address   st tx_queue rx_queue tr tm->when retrnsmt   uid  timeout inode
0: 00000000: 5355 00000000:    0 0A 00000000:00000000 00:00000000 00000000   996        0 17367 1 000000007135f841 100 0 0 10 5
1: 5A03000A:37434 0103000A:56287 01 00000000:00000000 00:00000000 00000000     0        0 63959069 1 00000000d3f8ce9f 20 4 30 10 -1
2: 5A03000A:39470 0103000A:56287 01 00000000:00000000 00:00000000 00000000     0        0 66522197 1 000000005a76bfdc 20 4 0 10 -1
3: 5A03000A:51448 2497CB9F:28915 01 00000000:00000000 00:00000000 00000000     0        0 57876344 1 000000004cc18c13 33 4 30 2 2
4: 0100007F:45398 0100007F: 7152 06 00000000:00000000 03:00000BD0 00000000     0        0 0 3 000000002d3c02cb
sl  local_address                         remote_address                        st tx_queue rx_queue tr tm->when retrnsmt   uid  timeout inode
0: 00000000000000000000000000000000: 7152 00000000000000000000000000000000:    0 0A 00000000:00000000 00:00000000 00000000     0        0 57879756 1 000000004dec4d04 100 0 0 10 0
1: 00000000000000000000000000000000:23334 00000000000000000000000000000000:    0 0A 00000000:00000000 00:00000000 00000000     0        0 57876363 1 00000000f5eefe02 100 0 0 10 0
2: 00000000000000000000000000000000: 5355 00000000000000000000000000000000:    0 0A 00000000:00000000 00:00000000 00000000   996        0 17374 1 0000000061bd1e01 100 0 0 10 5
3: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:35738 06 00000000:00000000 03:00000FBC 00000000     0        0 0 3 0000000060395487
4: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:45388 06 00000000:00000000 03:00000BD0 00000000     0        0 0 3 00000000e140663f
5: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:44514 06 00000000:00000000 03:00000006 00000000     0        0 0 3 00000000bea37b28
6: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:38604 06 00000000:00000000 03:000003F7 00000000     0        0 0 3 00000000fa296808
7: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:49244 06 00000000:00000000 03:000013AA 00000000     0        0 0 3 000000003717192f
8: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:35726 06 00000000:00000000 03:00000FBC 00000000     0        0 0 3 00000000f3cf3f99
9: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:34888 06 00000000:00000000 03:000007E4 00000000     0        0 0 3 00000000c9378e64
10: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:34880 06 00000000:00000000 03:000007E4 00000000     0        0 0 3 000000004ee515af
11: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:49250 06 00000000:00000000 03:000013AA 00000000     0        0 0 3 00000000e32b819b
12: 0000000000000000FFFF00005A03000A:23334 0000000000000000FFFF00001F00A8C0:62553 01 00000000:00000000 00:00000000 00000000     0        0 57878528 1 00000000db92b3f7 27 4 31 5 4
13: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:44508 06 00000000:00000000 03:00000006 00000000     0        0 0 3 000000002d8a7a4f
14: 0000000000000000FFFF00000100007F: 7152 0000000000000000FFFF00000100007F:38606 06 00000000:00000000 03:000003F8 00000000     0        0 0 3 00000000e2fd715d
15: 0000000000000000FFFF00005A03000A:23334 0000000000000000FFFF00005500A8C0:52666 01 00000000:00000000 00:00000000 00000000     0        0 57878527 1 000000006c81a486 22 4 30 6 4
You can see the port 23334 listening and 2 connections to it listed. Note these are IPv6.
or maybe slightly less cryptic:
start9@:~$ c=`start-cli package stats --format json | jq -r .datum.container_id`
start9@:~$ p=`sudo lxc-info  -n $c -pH`
start9@:~$ sudo nsenter -t $p -n ss -at | grep 23334
LISTEN    0      10                      *:23334                     *:*
ESTAB     0      0      [::ffff:10.0.3.90]:23334 [::ffff:192.168.0.31]:62553
ESTAB     0      0      [::ffff:10.0.3.90]:23334 [::ffff:192.168.0.85]:52666
start9@:~$
That may be in the container. However, it’s unreachable outside it, (in my case) ie. ssh Start9 machine:
netstat -ano | grep 23334 | no open port.
the output of your commands is affected by the different namespaces in use for each of the containers and the host. I get exactly the same output as you do when I run your command on my start9 host, yet my Datum server services my bitaxe machines OK. Try running my commands on your host.
OK
nc: connect to 192.168.254.12 port 23334 (tcp) failed: Connection refused
I have Datum installed in a VM on the same network:
nc -zv 192.168.50.6 23334
Connection to 192.168.50.6 23334 port [tcp/*] succeeded!
What am I missing?
BTW, On that note. This is not only this app. But bitcoin core: ZeroMQ ports 28333 & 28332.
I think someone on this forum has made that observation.
Those look like they’re on different networks?
Behind the same router on a VLAN with the StartOS machine on the default VLAN 1.
I asked AI:
The most likely cause is that **the service is listening inside the container’s network namespace, not on the LXC host**. Connecting to `1.2.3.4:23334` reaches the host’s IP stack; it does not automatically reach a container.
Common causes include:
- **No port forwarding/NAT or proxy:** The container may have its own address, such as `10.0.3.25`, and the service is reachable at `10.0.3.25:23334`, but nothing is listening on `1.2.3.4:23334`.
- **Service bound only to loopback:** Inside the container, it may listen on `127.0.0.1:23334` rather than `0.0.0.0:23334` or the container’s LAN address.
- **Wrong host/container address:** The container may be bridged directly and have its own IP; the host IP is not the correct destination unless forwarding is configured.
- **Host firewall actively rejecting the port:** An `iptables`/`nftables` rule using `REJECT` can produce an immediate “connection refused.” A `DROP` rule usually causes a timeout instead.
- **Container firewall rejecting the connection:** Similarly, firewall rules inside the container can reject traffic.
- **Incorrect port-forwarding rule:** DNAT may point to the wrong container IP or port, use the wrong interface, or fail to handle return traffic.
- **Service listening on IPv6 only:** It might listen on `[::]:23334` while the client is connecting over IPv4 to `1.2.3.4`.
- **LXC network isolation or bridge configuration:** The container interface may be down, attached to the wrong bridge, or not connected to the expected network.
- **The service exited or restarted:** A process can appear configured correctly while no process is currently listening.
Check from inside the container:
```bash
ss -ltnp | grep 23334
You want to see something like:
```text
0.0.0.0:23334
or the container’s actual IP, not only:
```text
127.0.0.1:23334
Then test locally and from the host:
```bash
# Inside the container
nc -vz 127.0.0.1 23334
nc -vz <container-ip> 23334
# On the LXC host
nc -vz 1.2.3.4 23334
Inspect the addresses and routes:
```bash
# Inside container
ip addr
ip route
# On host
ip addr
ip route
If the service should be reached through the host address, verify that forwarding exists. For example, a DNAT rule would conceptually look like:
```bash
iptables -t nat -A PREROUTING \
  -d 1.2.3.4 -p tcp --dport 23334 \
  -j DNAT --to-destination <container-ip>:23334
You may also need forwarding enabled and an appropriate `FORWARD` rule:
```bash
sysctl net.ipv4.ip_forward
iptables -L FORWARD -n -v
nft list ruleset
The fastest way to distinguish the cases is packet capture:
```bash
# On the host
tcpdump -ni any tcp port 23334
Interpretation:
- **SYN arrives, host immediately sends RST:** no host listener, or an active reject.
- **SYN is DNATed and reaches the container, but container sends RST:** service is not listening on the container address/port.
- **SYN reaches the container and no reply returns:** firewall, routing, or service/network issue.
- **No SYN reaches the host:** the client is using the wrong address, has a local firewall issue, or there is a routing problem.
In a typical LXC setup, try the container’s own IP first. If that works but `1.2.3.4:23334` does not, the service is healthy and the missing piece is host-side port forwarding or a proxy listener.
Which network are you trying to connect from? Is the bitaxe on the same local network as the start9 server (and not on another subnet)? I have seen evidence that Local (as defined in the Interfaces tab in the StartOS GUI) connections are only permitted from the same local network that the Start9 host is on.
Does this work, from the Start9 host itself? (the empty reply is expected - it’s not the connection refused error)
start9@:~$ curl http://your-start9-192.168.ip-addr:23334/
curl: (52) Empty reply from server
It seems StartOS only allows (really) local network access through it’s nftables rules (here for my 192.168.0.16 start9 server, you can see no 0.0.0.0/0 saddr is defined for port 23334):
start9@:~$ sudo nft  list ruleset | egrep 'table|chain|23334'| head -23
table ip startos {
	chain prerouting {
		ip saddr 192.168.0.0/24 ip daddr 192.168.0.16 meta l4proto { tcp, udp } th dport 23334 dnat to 10.0.3.61:23334 comment "F779ce76f8071f5f"
		ip saddr 10.0.3.0/24 ip daddr 192.168.0.16 meta l4proto { tcp, udp } th dport 23334 dnat to 10.0.3.61:23334 comment "F779ce76f8071f5f"
		ip saddr 127.0.0.0/8 ip daddr 127.0.0.1 meta l4proto { tcp, udp } th dport 23334 dnat to 10.0.3.61:23334 comment "F9150d6de2e8809b"
		ip saddr 10.0.3.0/24 ip daddr 127.0.0.1 meta l4proto { tcp, udp } th dport 23334 dnat to 10.0.3.61:23334 comment "F9150d6de2e8809b"
		ip saddr 10.0.3.0/24 ip daddr 10.0.3.1 meta l4proto { tcp, udp } th dport 23334 dnat to 10.0.3.61:23334 comment "Feb73d407f315100"
	chain output {
	chain postrouting {
		fib saddr type local ct original ip daddr 192.168.0.16 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "F779ce76f8071f5f"
		ip saddr 10.0.3.0/24 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "F779ce76f8071f5f"
		fib saddr type local ct original ip daddr 127.0.0.1 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "F9150d6de2e8809b"
		ip saddr 10.0.3.0/24 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "F9150d6de2e8809b"
		fib saddr type local ct original ip daddr 10.0.3.1 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "Feb73d407f315100"
		ip saddr 10.0.3.0/24 ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 masquerade comment "Feb73d407f315100"
	chain forward {
		ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 ct state new accept comment "F779ce76f8071f5f"
		ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 ct state new accept comment "F9150d6de2e8809b"
		ip daddr 10.0.3.61 meta l4proto { tcp, udp } th dport 23334 ct state new accept comment "Feb73d407f315100"
First of all thanks for working on this with me. I appreciate it.
You are correct! I again logged in to a machine that’s on the same local network as the Start9 machine and indeed StartOS is only allowing local network access.
On a side note, this seems to be also the case for Bitcoin Core ZeroMQ ports 28332-28333.
The only remedy at this point is to put the miners on the same network. I guess. Which is kind of inconvient. Hmmm. Or?
you could perhaps add more nftables rules for your other subnets, using the chroot-and-upgrade method, but it’s a bit techy. Depends on your comfort level. Or maybe try adding a public IP URL and see if your bitaxe can access that IP?
