I am currently on StartOS 0.4.0.2 and have these installed:
- Bitcoin Knots (pre-RDTS) #knotsprerdts:29.3:29
- Electrs 0.11.1:20
- Mempool 3.3.1:25
I would like to run the Blake2B chain in parallel/alongside, and point the Shrike wallet at it. I have found Pauls repository (https://start9.paulscode.com), and I think adding these services should do the trick if I understand it, as they would use different ports than the ones above.
- Bitcoin Knots (BLAKE2b) Companion (Is a pruned version of the blake2b chain)
- Electrs Pruned
- Mempool Pruned
Has anybody already tried this?
I’m doing this currently and Pauls Companion services run just fine. The only difference is my main electrum service is via Fulcrum, not Electrs. It can take a while if you plan on switching to Fulcrum but there is ‘probably’ no need. You lose nothing by trying it out - Good luck!
I am currently finishing to do this. I am using Paul’s Sha256 Knots version to run as a companion to Knots Blake2b. However, Its taking forever to complete initial sync even though its a pruned version. Scha256 has the spam and extra weight, but your sync would be the blake2b companion version–maybe it will be faster. I am not using Paul’s Electrs Pruned however.
I have trouble adding either the Paul’s Code registry mentioned above or the mempool.guide registry Kratter talks about on my Marketplace. It always tells me:
"Error
RPC ERROR: Not Found"
Have these been disabled? What’s the best way to install Knots and Fulcrum to set up a XBT node?
Made it work. Not finding the Registry was probably related to the outdated StartOS-version I was using.
Can confirm it works as expected, running Paul Lambs services alongside the other ones, as they all use different ports.
