— Title: Saving orphaned bitcoind data after failed 0.3.5.1 → 0.4.1.1 migration — “no migration path” blocks all installs. How do I adopt my existing blockchain into a working Bitcoin service?
Category: StartOS Support (Services)
My primary goal: preserve my existing blockchain data (~600 GB, fully synced before the upgrade) rather than re-syncing from scratch. Please tell me clearly whether this is possible on 0.4.1.1, and if so, the exact steps.
My setup:
- Server: Server One (x86_64)
- OS before: StartOS 0.3.5.1 with Bitcoin Knots 29.3.1 (
#knots:29.3.1:0), electrs, Tor — chain fully synced - OS now: 0.4.1.1
- Upgrade method: over-the-air (System → Begin Update)
Everything I’ve done, in order:
Made a complete backup first: updated all services on 0.3.5.1, stopped everything, backed up to a 57.6 GB USB flash drive via System → Backups (0.3.5.1 format backup, pre-upgrade). I understand this can only restore onto 0.3.5.1, not 0.4.x — treating it as rollback-only.
Ran the OTA update to 0.4.0, which completed.
Immediately received this notification:
Services Failed To Migrate — Failed to migrate the following services from 0.3.5.1: Bitcoin Knots. YOUR DATA IS SAFE. Simply re-install these services from the marketplace.
Technical cause logged:
Migration Failed — bitcoind — S9PK Parsing Error: image archive has no image for the requested platform -
Bitcoin disappeared from my Services list entirely — only electrs and Tor remain. There is no bitcoind entry visible to uninstall, update, or reinstall from the Services page. The migration notification has no “view details” or action buttons.
Marketplace install attempt — Bitcoin Knots (pre-RDTS) → failed:
Error: this service has no migration path from #knots:29.3.1:0 to #knotsprerdts:29.3:31, so its data cannot be carried over -
Marketplace install attempt — Bitcoin Core 31.2 → failed:
Error: this service has no migration path from #knots:29.3.1:0 to 31.2:1, so its data cannot be carried over -
Hard-refreshed, checked Notifications, Services, Marketplace — no way to abandon the orphaned data or clear the old package registration.
NOT yet tried: sideloading. Based on the PaulsCode “Recovering from Stalled Chain Split” guide, I understand the pre-RDTS package
29.3.knots20260507“takes over your existing Bitcoin data rather than starting a new sync” and is built for both processor platforms. Before I sideload it, I want to make sure that’s the right move so I don’t make the situation worse. -
Tor is running with bridges active — working perfectly on 0.4.1.1.
electrs is NOT running — it shows a status error indicating it “needs Bitcoin Core” or “requires latest Bitcoin Core version.” Without Bitcoin, electrs is useless anyway.
My understanding of the situation (correct me if wrong): The original migration failed because the old Knots package couldn’t be parsed (“no image for the requested platform”), leaving the bitcoind volumes orphaned on disk while the package-store registration for #knots:29.3.1:0 remained. Every install attempt — Knots pre-RDTS or Core — is treated as a migration from that ghost registration, fails the migration check, and aborts. The notification said “simply re-install,” but reinstalling is precisely what keeps failing.
My questions — please answer each directly:
- Is my existing blockchain data recoverable on 0.4.1.1 at all? Yes or no. If yes:
- What are the exact steps to attach my existing bitcoind volumes to a working Bitcoin service — which package/version should I install (Core 31.2, Knots pre-RDTS, or the sideloaded pre-RDTS
29.3.knots20260507?), and in what order? - Is sideloading the pre-RDTS
29.3.knots20260507package safe and advisable in my situation? Or will it hit the same migration block? If it’s the right move, should I do anything first (clear the notification, adjust config, free disk space)? - If my data cannot be adopted: what is the supported way to abandon/delete the orphaned bitcoind registration and volumes so a fresh install can proceed? Exact steps please (UI, or SSH/CLI commands if that’s required — I can run SSH commands and share output).
- Before I do anything: are there any commands or actions that would make the data unrecoverable (e.g., does clicking Uninstall anywhere delete the orphaned volumes)? I want to avoid destroying my one chance to save the sync.
- electrs: it currently refuses to run without Bitcoin Core. Once Bitcoin is restored (whether Knots or Core), will electrs automatically start working, or will it require reconfiguration?
- Version preference: if my data can be adopted, I strongly prefer Bitcoin Knots pre RDTS or Core 29.x if available, since it’s closest to my original Knots 29.3.1 and may have better compatibility with the existing data format. Does 0.4.1.1 offer older major versions in the marketplace, or only the latest?
If it helps your diagnosis: my install attempt logs are timestamped Nov 5, 00:38 / 00:40 / 00:57 / 01:09 (the errors quoted above), and the migration-failure log entry (S9PK Parsing Error) is from Nov 5, 00:29, immediately after “Welcome to StartOS 0.4.0”.
Thank you — I’m happy to provide any additional logs, SSH output, or screenshots you need.
Update — additional blockers discovered (Nov 5, ~8 hrs later):
I’ve kept digging while waiting, and there are two new pieces of information for whoever picks this up:
1. The pre-RDTS sideload package is rejected by the UI as legacy format.
Following the PaulsCode “Recovering from Stalled Chain Split” recovery guide, I downloaded the Retropex pre-RDTS package v29.3.knots20260507 (the build documented as “taking over existing Bitcoin data rather than starting a new sync”), verified its SHA-256 (3a57a796...f1dc, matches both the release page and the bip110.org guide). When I attempt to sideload it via System → Sideload Service on 0.4.1.1, I get:
“Version 1 s9pk detected. This package format is deprecated. You can sideload a V1 s9pk via start-cli if necessary.”
So the UI hard-rejects v1-format packages.
2. My questions now, restated as directly as possible:
- Can my orphaned bitcoind data (from
#knots:29.3.1:0, volume still on disk, never uninstalled) be adopted by ANY installable package on 0.4.1.1? If yes — which one, and exact steps. - Is CLI sideloading the answer to the v1 rejection? I have SSH access and am comfortable running
start-clicommands. From the docs I’ve foundstart-cli package install --sideload <file>. Will this (a) accept a v1 package, and (b) bypass or hit the same “no migration path from #knots:29.3.1:0” migration check? Exact command sequence appreciated, including how to get the local file onto the server first (SCP? USB?). - Is there a v2-format build of the pre-RDTS
29.3.knots20260507code anywhere? The Start9-Communitybitcoin-knots-prerdts-startosrepo publishes v2-format packages (#knotsprerdts:29.3:27/:28/:31) — but Marketplace install of:31fails on the migration-path check. Is there any of those versions that would install as a fresh install and pick up the existing volume, per the 0.4.0 docs statement that “StartOS keeps the service’s volume on disk if migration fails. Install the service again from the marketplace and it will pick that data back up”? - If preservation is genuinely impossible, what is the supported way to abandon the orphaned data and registration so a clean Core 31.2 install proceeds? (I will not click Uninstall — I understand it deletes the data volume.)
- Priority flag: I would strongly prefer to preserve the blockchain. I’m prepared to run any supported CLI procedure under your guidance.
Current state: Tor (bridges) working fine; electrs idle (demands latest Bitcoin Core); no bitcoind entry anywhere in Services; ghost registration from #knots:29.3.1:0 intercepts all installs. Logs timestamps in original post.
