On StartOS 0.3.5.1, all my .onion addresses time out, even the main dashboard address in Tor Browser. My Tor Browser works fine otherwise, but Sparrow 2.5.6 can’t reach electrs. Is this caused by the Tor network’s new protocol requirements, and will updating to 0.4.0 fix it?
Please update to StartOS v.0.4.1.1
I am having the same issue with Sparrow and have updated to 4.1.1. Even before 4.1.1, TOR was erratic since the big update. I’ve rebooted and generated a new .onion address but nil help. Any suggestions?
If Tor is not working on your server you should check Tor service logs to see what is going on.
The latest version of Sparrow is 2.5.6
If Sparrow is not working you can’t update to the latest version via the app
I solved my Tor/Sparrow connectivity issue by going directly to Download - Sparrow Wallet to get the latest version, installed it on my computer, then restarted.
Now connection works fine with my Start9. I’m also using the latest versions of Start9 apps, including Tor.
