Vaultwarden 1.37.4:3 shows Running in StartOS, but the web vault never loads on any address or device. The logs show a clean start, with Rocket launched on port 80 and no errors. Restart and a full stop and start didn’t help, and server CPU and memory are normal. This started after I updated StartOS to 0.4.1.1.
Also, the native Bitwarden iPhone app has never been able to log in to this server, giving “username or password is incorrect,” though the web vault accepted the same password.
I have not tried Reinstall, since this is my password vault. Does Reinstall keep the vault data, and what’s the safe fix?
Don’t reinstall. Your vault data should be fine. It’s stored on the server, and Vaultwarden starting cleanly with no errors means it’s reading it. A reinstall also wouldn’t fix this, because nothing so far points at Vaultwarden itself. The problem is more likely somewhere between your browser and the service.
The iPhone app is a separate issue. “Username or password is incorrect” while the web vault accepts the same password usually means the app is logging in to Bitwarden’s own servers, where your account doesn’t exist. Once the web vault loads again, change Logging in on to Self-hosted on the app’s login screen and enter your Web Vault’s https address. For a .local address your iPhone also needs your server’s Root CA installed and trusted. If the iPhone refuses to install it, StartOS 0.4.1.2 should fix that.
What to do next depends on what the browser shows when you open the Web Vault. A certificate warning or error: that device doesn’t trust your server’s Root CA, so download it again from StartOS and install it there. A message from Vaultwarden asking for HTTPS or a secure connection: use the https address, not the http one. A blank page or a spinner that never finishes: try a private window, and if the vault loads there, clear that site’s data in your browser. If other services’ pages won’t open from that browser either, the problem is on the server rather than in Vaultwarden, and restarting the server is the next thing to try.
