Getting this error:
Access through untrusted domain
I edited the “trusted_domains” setting in config/config.php and added
array (
0 => ‘address.local’,
1 => ‘address.onion ’,
2 => ‘10.10.20.51’,
3 => ‘[fe80::1:50]’,
Restarted service and still no access
Rexter
August 29, 2024, 3:46pm
2
Please provide some context. Are you trying to connect to NC remotely?
Yes and also locally both give me the same result.
Rexter
August 29, 2024, 5:29pm
4
Did you follow the setup guides? Specifically the Trusting Your Root CA guide.
https://docs.start9.com/0.3.5.x/user-manual/trust-ca#trusting-your-root-ca
No I did not let me try this tonight.
Thanks
Unfortunately this link did not help. Same situation.
OK I decided to uninstall the Nextcloud service.
And re-install it.
All OK
Rexter
August 30, 2024, 1:07pm
8
Great! The Root CA setup needs to be done any any device that will connect to your StartOS server. So that the device can establish a secure connection to your server.
Yes, thanks for your help on this.
