My Start9 server version is 0.4.0.1 so I am assuming that I don’t need SimpleProxy as the instructions for Datum Gateway specifically mentions that is required for version 0.3.5.1.
My Bitaxe configuration is as follows.
Pool Configuration:
-Stratum Host: 192.168.18.6 (my Start9 address)
-Stratum Port: 23334 (default as per Datum Gateway documentation) however, I did notice that Datum Gateway listening port is 23335
-User: My wallet address
-Password: ***** (12345)
Fallback Pool Configuration:
-Stratum Host: solo.ckpool.org
-Startum Port: 3333
My Datum Gateway configuratio is as follows.
Config > Mining Settings > Bitcoin Address > My wallet address
Config > Datum > Pool Host > Blanked out / empty
Config > Datum > Collaborative reward sharing (pooled mining) > never (non-pooled only)
All dependencies (Bitcoin Knots) are satisfied and running.
Unfortunately, I keep getting the following warning on the Bitaxe, “Using fallback pool - Share stats reset. Check Pool Settings and / or reboot Device.”
I have tried restarting services on Start9 as well as the Bitaxe itself. I also tried both ports 23334 and 23335 when pointing my Bitaxe to the Start9 Datum Gateway.
Any suggestions on how I can get Bitaxe to use the Primary pool and stop it from reverting to the fallback pool?
