DIY Bitcoin Core in a start sync start loop. All other services besides ones that rely on core are working fine.
The SIGBUS suggests something terrible going on with your hardware… probably the SSD. There may be further details in the Kernel logs, under System.
You can also try reindexing the blockchain under Bitcoin → Actions, but I think you have a hardware issue.
Thank you. That is unfortunate because that would be the second Teamgroup SSD to fail on me.
I will start swapping hardware to see if i can fix.
Thanks again.
