Bitcoin Core not starting
I’m running Bitcoin Core v31.1:16 on 0.4.0.1.
Since the update to said version the service won’t start. I tried stopping it and all other services and restarting the server. Nothing works. It’s stuck at the sync stage.
Would the log file be useful?
Look at the logs @ Services > Bitcoin Core > Logs. Maybe paste the last ~50 lines before a restart here if you need help interpreting it.
Usually it will indicate that some action needs to be taken at Services > Bitcoin Core > Actions & Config
15T04:14:19Z Starting HTTP server with 16 worker threads
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_1 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_0 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_2 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_3 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_5 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_4 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_6 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_7 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_12 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_9 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_15 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_10 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_11 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_14 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_13 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z http_pool_8 thread start
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Using /16 prefix for IP bucketing
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z init message: Loading P2P addresses…
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Loaded 73481 addresses from peers.dat 323ms
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z init message: Loading banlist…
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z SetNetworkActive: true
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Cache configuration:
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z * Using 2.0 MiB for block index database
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z * Using 128.0 MiB for transaction index database
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z * Using 112.0 MiB for basic block filter index database
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z * Using 8.0 MiB for chain state database
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z * Using 774.0 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Script verification uses 5 additional threads
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Using obfuscation key for blocksdir *.dat files (/root/.bitcoin/blocks): ‘16c654146a2f6762’
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Opening LevelDB in /root/.bitcoin/blocks/index
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Opened LevelDB successfully
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Using obfuscation key for /root/.bitcoin/blocks/index: 0000000000000000
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Using 16 MiB out of 16 MiB requested for signature cache, able to store 524288 elements
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Using 16 MiB out of 16 MiB requested for script execution cache, able to store 524288 elements
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z init message: Loading block index…
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Assuming ancestors of block 00000000000000000000611fd22f2df7c8fbd0688745c3a6c3bb5109cc2a12cb have valid signatures.
2026-09-15T06:14:19+02:00 2026-09-15T04:14:19Z Setting nMinimumChainWork=0000000000000000000000000000000000000001128750f82f4c366153a3a030
2026-09-15T06:14:20+02:00 daemon synced-true waiting on sync-progress
2026-09-15T06:14:20+02:00 Launching sync-progress…
2026-09-15T06:14:20+02:00 Launching index-sync…
2026-09-15T06:14:23+02:00 2026-09-15T04:14:23Z Loading block index db: last block file = 5750
2026-09-15T06:14:23+02:00 2026-09-15T04:14:23Z Loading block index db: last block file info: CBlockFileInfo(blocks=73, size=111125145, heights=966428…966500, time=2026-09-11…2026-09-11)
2026-09-15T06:14:23+02:00 2026-09-15T04:14:23Z Checking all blk files are present…
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Initializing chainstate Chainstate [ibd] @ height -1 (null)
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Opening LevelDB in /root/.bitcoin/chainstate
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Opened LevelDB successfully
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Using obfuscation key for /root/.bitcoin/chainstate: 933041b3f42c4665
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Loaded best chain: hashBestChain=000000000000000000011ada8812e1b93daabaea5f4f90b1920e8212a11a36ca height=966500 date=2026-09-11T11:35:19Z progress=0.998802
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z init message: Verifying blocks…
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Verifying last 6 blocks at level 3
2026-09-15T06:14:24+02:00 2026-09-15T04:14:24Z Verification progress: 0%
2026-09-15T06:14:30+02:00 2026-09-15T04:14:30Z Verification progress: 16%
2026-09-15T06:14:38+02:00 2026-09-15T04:14:38Z Verification progress: 33%
2026-09-15T06:14:42+02:00 2026-09-15T04:14:42Z Verification progress: 50%
2026-09-15T06:14:45+02:00 2026-09-15T04:14:45Z Verification progress: 66%
2026-09-15T06:14:49+02:00 2026-09-15T04:14:49Z Verification progress: 83%
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Verification progress: 99%
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Verification: No coin database inconsistencies in last 6 blocks (23733 transactions)
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Block index and chainstate loaded
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Opening LevelDB in /root/.bitcoin/indexes/txindex
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Opened LevelDB successfully
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Using obfuscation key for /root/.bitcoin/indexes/txindex: 0000000000000000
2026-09-15T06:14:52+02:00 2026-09-15T04:14:52Z Opening LevelDB in /root/.bitcoin/indexes/blockfilter/basic/db
2026-09-15T06:14:53+02:00 2026-09-15T04:14:52Z Opened LevelDB successfully
2026-09-15T06:14:53+02:00 2026-09-15T04:14:52Z Using obfuscation key for /root/.bitcoin/indexes/blockfilter/basic/db: 0000000000000000
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z [error] previous block header belongs to unexpected block 000000000000000000002b9b942ee9ae9da493eed410ea71340241ea3e273d0a; expected 000000000000000000011ada8812e1b93daabaea5f4f90b1920e8212a11a36ca
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z [error] Cannot read last block filter header; index may be corrupted
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_1 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_14 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_12 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_5 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_3 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_2 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_13 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_0 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_4 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_6 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_9 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_10 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_15 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_11 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_8 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z http_pool_7 thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z Shutdown in progress…
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z scheduler thread exit
2026-09-15T06:14:53+02:00 2026-09-15T04:14:53Z Shutdown done
2026-09-15T06:14:53+02:00 Error: bitcoind exited with code 1
2026-09-15T06:14:53+02:00 at ChildProcess. (/usr/lib/startos/package/index.js:4521:39)
2026-09-15T06:14:53+02:00 at ChildProcess.emit (node:events:524:28)
2026-09-15T06:14:53+02:00 at ChildProcess._handle.onexit (node:internal/child_process:293:12)
2026-09-15T06:14:53+02:00 daemon sync-progress waiting on bitcoind
2026-09-15T06:14:53+02:00 daemon synced-true waiting on sync-progress
2026-09-15T06:14:53+02:00 daemon index-sync waiting on bitcoind
2026-09-15T06:14:53+02:00 Health Check bitcoind failed: bitcoind daemon crashed
2026-09-15T06:14:53+02:00 Stopping sync-progress…
2026-09-15T06:14:53+02:00 Stopping index-sync…
Help please! :smiling_face_with_three_hearts: (it’s still stuck)
I fixed it . Reindexing was what Klaus recommended based on my log file.
