Bitcoin Core Synch constantly timing out - Ping test 0ms, 0% packet loss - Wired LAN - No firewall
Hi Dave, that’s great to know! I thought my hardware was ok, good to know that maybe it’s not
I was thinking for the future to update it with this → https://www.amazon.it/gp/aw/d/B0BBSFYYRZ/ref=ox_sc_saved_image_5?smid=A1OIUNRC0ZQ15R&psc=1 or this → https://www.amazon.it/gp/aw/d/B0C8J2NHXX/ref=ox_sc_saved_image_3?smid=A1OIUNRC0ZQ15R&psc=1
I think they will be far better, but since it seems I’m not good at estimate and evaluate hardware, it would be great to have a judgement about :innocent:
Thank you so much!
These would be much more powerful. In general, we like the Mini PC and Thin Client options, namely for the form factor, but a desktop tower will work just as well. You can check out this thread to see what others are using.
Thanks dave, will give it a check! I agree with you but I prefer to sacrifice the form factor to gain in performance, plus I found that mini PCs tend to cost a bit more than tower refurbished PCs
Thank you again, I’m an ex Umbrel user and I found heaven with Start9, both with forum and OS :zap:
I have same problem as OP, triangles are blinking constantly. Can it be caused by LAN physical structure? My server is connected through switch, then switch, then to optical router. All wires, no radio.
I’m experiencing the same issue. I’m running a Promox hypervisor on good hardware, my StartOS VM has 4 cores and 16GB of RAM. Nothing is usable, all Web UI’s are extremely slow. All RPC health checks constantly timing out…It’s very frustrating, this is the third or fourth install I do of StartOS and for some reason I can never get a good user experience.
