Bitwarden Firefox extension not connecting on linux mint client
“netwotk error when trying to fetch resource”
I got the Bitwarden standalone app working, but can’t get the firefox extension to connect. I added the s to the http onion address, I downloaded the proxy as recommended in the start9 user guide, I set up firefox for tor and for the automatic proxy, to no avail.
Hi. What version of Linux Mint is this on? Do you need remote syncing, or is this machine always on your lan?
It’s LM 22.2. This machine is always remote.
This is probably related to the sandboxed version of Firefox LM ships with. But we need to make sure the other boxed are checked first. Did you go through the device setup, where you imported your server’s root CA?
yes for the root CA, Also, I have no problem accessing the server remotely from firefox on the same machine. Furthermore, Nextcloud is synchronizing fine.
Hi prosper!
If I understand correctly, you’re only having issues with the browser extension while everything else works fine over Tor. This suggests Firefox might be running in a jailed environment like an AppImage, Flatpak, or Snap. Try installing Firefox using a .deb package instead, which won’t isolate it from the regular filesystem.
Here’s a helpful guide I found:
Let us know if that solverd your issue.
looks like a major firefox overhaul, may not do it today. Any chance this will be fixed on Start9 version 0.4?
This isn’t an issue with StartOS—it’s a client-side connectivity problem, so there’s nothing to fix on the server. Saying that StartOS v0.4.0 will include enhanced networking options to make connecting clients more robust.
Hi, I am back to this problem now. I just tested with a laptop running also Linux Mint, but I am local and can use either the local or the tor interface to the server. When I opened the laptop, Vaultwarden was working and synching on both Firefox and Librewolf. Then, I got a bunch of updates done to the system as I had not used it for a while. After that, Vaultwarden stopped synching on both browsers, both locally and remotely
and then, after login out and back in, it stopped showing even the last version of passwords. Note that I checked that Firefox was the deb package version
There’s too many moving parts here. We need to find lines of differentiation. Please tell me more about how you are syncing with Vaultwarden both locally, and remotely. What browser do you intend to use?
I specified that I tried with both Firefox and librewolf: same result. I have installed the bitwarden extension on both, specified the self host from my vaultwarden app on start9, tried it with both local and tor interfaces and none worked. That problem started after an update of the linux system.
I have no problem with my windows PCs
Okay, great. Let’s focus on Firefox first. Bitwarden’s caching works quite well, so .local only works for most people. But if you want more real time syncing, you can use the .onion interface. Which way do you want to go?
right now, I am remote, therefore I can only use the .onion interface
