Hello community,
I am a rookie to running my own node, will be very appreciative for any guidance out there! Specs I’m running:
Raspberry PI 4 8GB, 20W power supply, 128GB Max Endurance micro sd card.
I installed BTC Core and began initial sync maybe 6 weeks ago. Got till about 70% then slowed down big time, but slowly kept moving. Then last week got to about 86%, and now when I look in logs, I see that it is stuck. I see:
[2025-03-09T16:51:44Z ERROR btc_rpc_proxy] hyper failed to process HTTP request
2025-03-09T16:51:44+00:00 Error updating network info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332 (error code 1 - “EOF reached”)
2025-03-09T16:51:44+00:00 Make sure the bitcoind server is running and that you are connecting to the correct RPC port.
Can someone pls advise on how I can get unblocked? Thanks in advance!
