Chroot-and-upgrade seems to fail
HI
Im trying to add simpleproxy, but when I run /usr/lib/startos/scripts/chroot-and-upgrade it seems to stop at around 5%, never getting to the end of the rsync, I presume the rsync should get to 100%?
Syncing…
175 0% 0.00kB/s 0:00:04 (xfr#1, to-chk=0/62263)
if I just run the sync command with -v
rsync -av --delete --force --info=progress2 /media/embassy/embassyfs/current/ /media/embassy/next
sending incremental file list
0 0% 0.00kB/s 0:00:00 (xfr#0, to-chk=0/62263)
sent 1,316,132 bytes received 5,887 bytes 881,346.00 bytes/sec
total size is 3,512,831,213 speedup is 2,657.17
Which doesn’t give me much to go on,
I am using 0.3.5~1
Anyone else successfully completed the chroot upgrade recently?
Thanks
Rather than implementing some painstaking step by step attempt to fix (I have no idea what could possibly be wrong)… it’s probably best just to “start over” by reflashing StartOS onto this server.
This doesn’t mean losing any of the services you’ve installed, or any data, it just replaces your borked OS with a fresh unborked copy.
You’d see this here: Start9 | StartOS (x86/ARM)
You’d create the USB with the right version of the OS based on your device.
At the end of the process, you’d choose to “Re-install”, remove the USB and restart.
Then you’d do this… Start9 | Use an Existing Data Drive
Choose recover, Use Existing Drive and complete the process.
Great, thank you, I did that and all ok now
thanks
