Hello!
Does anyone know how to connect Liana wallet to their Start9 server? I just switched from Umbrel recently. It was pretty simple on my old node, but I cant figure out how to get it to work on Start9. I’d appreciate any help ![]()
Hello!
Hi! I would refer you to the Liana guides.
If you need help finding the specific info requested, I can help you find it in StartOS. But I would need to know specifically what you are looking for.
Cool thanks! Their guide isn’t too helpful
I know on Umbrel you just put in your local IP address and add :50001 on the end. But I can’t figure out my local IP address for Start9
Hi
This IP:port won’t work on the current version of StartOS, because StartOS uses mDNS for connecting over your local network and Tor for remote access. This setup will change soon. StartOS 0.4.0 is currently in late alpha and should enter public beta very soon.
The upcoming update will allow you to utilize IP:port as well, making advanced VPN setups possible so you can access your service remotely without relying on Tor.
I think port 50001 is for electrs. The first question I’d have is, does Liana have proxy settings?
Not to my knowledge. I reached out to Kevin, one of the devs, and apparently v12 will help with my situation
Sounds good. Until the next version of StartOS, electrs is only available over tor, so unless Liana has it’s own tor daemon, or proxy settings to connect to system wide tor, there is no way to connect to electrs. Hopefully, they will prove that wrong.
