Hi! The first time I installed SimpleX (on Linux Mint), both the SMP and XFTP server connected successfully. I uninstalled SimpleX from Linux Mint because I wanted to go through the setup process again, but this time the XFTP server didn’t connect even though I was using the same address. I then uninstalled SimpleX from Linux Mint, and the Start9 server to get new addresses, but the issue remains. Please advise.
Perhaps look at the stability of your Tor connection?
Thanks! I asked AI about that. Any specific you have in mind? Could stability be the issue when the SMP server is connecting fine?
Has this message from the service logs something to do with it? xftp-server: /var/opt/simplex-xftp/file-server-store.log: openFile: does not exist (No such file or directory)
Solution: I started over again, and this time it worked.
