Core Lightning Channel rebalancing? Sling Plugin? Can't find a working solution
I am trying to find the best/easiest way to rebalance channels in Core lightning. The Ride The Lighting option for circular rebalancing is not possible with Core. There is, however, a plugin in the Core Start9 settings, under advanced, to enable “Sling.”
I enabled it and set up an SSH connection to the Start9 server. However, none of the sling commands work (such as sling-version).
I tried using
sudo podman exec -it c-lightning.embassy sling-version
as well as
sudo podman exec -it c-lightning.embassy bash
sling-version
Can anyone help with either getting sling working via SSH or directing me to a better way to rebalance a channel on Core Lightning Node?
I have not used the plugin but did a search on it. Does putting lightning-cli sling work after entering the container with sudo podman exec -it c-lightning.embassy bash?
lightning-cli sling “command”
Replace with the specific command you want to run, such as sling info or sling send.
No it doesn’t work. But that was a good idea considering it is a plugin. I hadn’t thought of trying that until you mentioned. But alas, no, it does not work.
I think we are on the right track. Someone from the community might be more familiar with it, or you could try reaching out to the CLN community. I supposed you took a look at the Github already?
Yes, StartOS had a link to the github page in the “important notice” section. That’s where I got the CLI commands to try.
Building on what others have stated…
  1. Exec into the container
  2. Safely inside, check that things work and exist
    lightning-cli getinfo
  3. Check sling version
    lightning-cli sling-version
  4. Add Sling jobs…
    lightning-cli sling-job -k scid direction amount maxppm (outppm) (target) (maxhops) (candidates) (depleteuptopercent) (depleteuptoamount) (paralleljobs)
  5. Run all added sling jobs
    lightning-cli sling-go
And obviously for this to work, you have to the sling plugin turned on in CLN’s config.
Well, for what ever reason this is working now. Perhaps it because I rebooted the StartOS server (which I am not sure I did after initially enabling the sling plugin).
Interestingly enough, it works. And then sometimes it doesn’t work.
root@c-lightning:/app# lightning-cli sling-version
   "code": -32601,
   "message": "Unknown command 'sling-version'"
I just started using the Sling plugin for CLN running on StartOS. I am finding it reliable and working for my needs. Just needed to create the Sling instructions one-time using -CLI commands, and so far it’s rebalancing behind the scenes as designed.
