When attempting to access the Core Lightning UI I get a " Could not establish a connection to node" error message. I also can’t see any channel balances in RTL. I have restarted the server and as well restarted Tor and the services and nothing seems to work.
When I look at the CLN logs I see the following error messages:
{“level”:“warn”,“message”:“\tServer running at http://0.0.0.0:4500”,“timestamp”:“2023-11-11 16:48:43:4843”}
There are two current issues being worked on right now:
Following the recent updates, there is a bug related to just the new UI add-on of CLN that prevents it from being displayed properly. Hopefully we get a fix pushed soon, I can try to alert you here when it’s ready, or if you’re able to come over to Telegram and send me a DM, I’ll let you know the progress as I check up on it.
There’s also and issue with RTL that means it requires a slightly more recent version of CLN than the one we currently have full tested in the registry. The replacement is in the Beta registry, but not 100% ready yet (and so you probably shouldn’t use it) - best bet is to use RTL 0.13.6~1 for now, and upgrade again later.
