Corrupted transactions indexes and chain state corruptions when trying to set up Start9 Server Pure with Btc Knots
Hello community, anyone knows how to fix this? (error message when trying to set up Sart9 Server Pure, running with Bitcoin Knots):
025-11-21T17:30:24+01:00 2025-11-21T16:30:24Z Fatal LevelDB error: Corruption: block checksum mismatch: /root/.bitcoin/indexes/txindex/000300.ldb
2025-11-21T17:30:24+01:00 2025-11-21T16:30:24Z You can use -debug=leveldb to get more complete diagnostic messages
2025-11-21T17:30:24+01:00 ************************
2025-11-21T17:30:24+01:00 EXCEPTION: 15dbwrapper_error
2025-11-21T17:30:24+01:00 Fatal LevelDB error: Corruption: block checksum mismatch: /root/.bitcoin/indexes/txindex/000300.ldb
2025-11-21T17:30:24+01:00 bitcoin in scheduler
2025-11-21T17:30:24+01:00 terminate called after throwing an instance of ‘dbwrapper_error’
2025-11-21T17:30:24+01:00 what(): Fatal LevelDB error: Corruption: block checksum mismatch: /root/.bitcoin/indexes/txindex/000300.ldb
2025-11-21T17:30:24+01:00 PROCESS TERMINATED BY SIGABRT
2025-11-21T17:30:39+01:00 Error updating blockchain info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332
2025-11-21T17:30:39+01:00 Make sure the bitcoind server is running and that you are connecting to the correct RPC port.
2025-11-21T17:30:39+01:00 Use “bitcoin-cli -help” for more info.
2025-11-21T17:30:39+01:00 Error updating network info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332
You’ll probably need to register for support at Start9.me using your support access code you were sent by email, so we can go through a few possible causes.
Hi Stuart, thank you so much for this reply. Luckily I got it sorted, the issue was caused by the Firewall. The blockchain synchronised successfully after plugging the server directly to the ISP router :sparkles:.
