Desktop Monitor Resolution
I was just wondering if there’s a way to get start OS to display in anything other than your monitor’s native resolution. I can increase the zoom on my browser to make the text bigger but other tools and text are obviously still rendered in tiny ultra high resolution. Thanks.
StartOS isn’t really designed to be connected to a monitor. It’s typically a last-ditch troubleshooting method to gain access when networking goes wrong.
Have you been following the guides? Those detail how you’re supposed to be using StartOS… from a web browser on another machine entirely.
https://docs.start9.com/0.3.5.x/user-manual/
Copy that. Just getting my feet wet and in the middle of setting up the primary PC I’m using to connect to it on the LAN. Thanks.
