I was having trouble building a second server on a Raspberry Pi4 in an Argon case with a M.2 SSD. I came to the conclusion HERE that I had been duped and sold fake 1TB SSD’s. I found I also had file system errors downloading the Bitcoin blockchain history on a Start9 server running in Proxmox which I took as confirmation that the SSD’s were the issue.
Now I have installed a good quality locally sourced 1TB SSD in the Raspberry Pi and find it has gone into Diagnostic Mode with a big error log pointing at a docker error. The initial log in the Bitcoin service logs pointed at a “Lost connection” but this may have been the docker repo?
I have tried re-starting, re-building etc using the Diagnostic mode buttons. I also tried the disk recovery but the result seems to be the same.
Is this likely something corrupt on the Pi’s SD card? Is it worth putting a newly flashed SD card into the server and trying to recover from the SSD? FYI: I had only one service installed (Bitcoin) and the failure happened during the blockchain download. There was also a power cut at home during the download.
Any insight would be appreciated
Thanks,
Garry
