Hi
I try to issue bitcoin-cli command but I’m unable to use docker (command not found)…
I’ve try with sudo and in root (sudo su - )
is that command deprecated in 0.3.5 ?
Thanks for your time
Hi
Try using podman instead of docker
Thanks…
So that was I was searching :
sudo podman container exec bitcoind.embassy bitcoin-cli …
Do you still have a question?
No, thanks for your help
