"Docker Error"... "No space left on device"
FYI that well over a year later you still have not updated the documentation to state that 1TB is actually not enough storage for running a bitcoin node:
https://docs.start9.com/0.3.5.x/diy/diy-x86.html
Those are the old v0351 docs.
StartOS v040 can still run Bitcoin, its probably still the most popular service on the platform. I think individual services should be responsible for explaining their own system requirements. Despite the popularity of any particular service, I don’t think StartOS Docs can list the individual requirements of 150+ services, or even know what they all are.
I found it (you could have linked to it): Installing StartOS - StartOS
I knew you thought that, but figured maybe we were past that point. Especially after you said as much. I guess not.
When did I, or anyone, even imply that to be a request, or argument, here? Answer: never once. Either you are just sidetracking intentionally, or maybe answering dialog here isn’t really your forte. If self-running a bitcoin node is what Start9 frequently mentioned, marketed, and were known for, then it should have been properly documented. My running out of storage, along with at least one other here, based on the documentation, PROVES that it was insufficient in that ONE case (not all of them, which you literally just made up yourself.)
And continues to be the case. So I’m done with this sidetracked discussion. I simply cannot recommend Start to anyone wanting to run their own DIY node moving forward, because it’s just simply too unsupported without the threat of major wasted resources.
Good day.
Fair enough. While we love our DIY-ers. As a business that is not yet profitable, Start9’s primary focus is on issues that effect our customers. StartOS is built for, and tested on specific hardware that we sell. I expect in the future, we will have the luxury of focusing on issued outside of that scope. But we’re not there yet. In the meantime, we maintain and interact with this forum regularly. We encourage our DIY community to interact, and share information among yourselves that may be helpful in that regard.
Personally all that would have been needed to have helped me not waste a TON of time on my DIY rig was have accurate enough minumum numbers for:
  1. the size the BTC node required (MORE than just the 1TB previously listed), and
  2. the monthly bandwidth required. Which only after the fact was the link provided to that webpage.
Why couldn’t those just be in the initial instructions?? Not the endless argument stance about “150+ services”.
That’s it. I would have made different choices and been a fan instead of just giving up and repurposing the hardware for other things now.
You guys put thousands of hours into all this, and then fumble that one at the goal-line. It’s crystal clear obvious to me. Apparently not to yall. But whatever.
I agree with you. The section in the 0.3.5.1docs you point out needs to be updated. Thank you for your follow up. I’ll see what I can do there. I don’t think the 0.4.0 docs make any such reference. As Stuart pointed out, this information probably belongs elsewhere such as the Bitcoin Core, or Bitcoin Knots package instructions. It’s obviously harder for a service like Nextcloud, or File Browser to know how much storage space you may need. But with the predictable nature of blockchain growth, I agree it’s seems reasonable that it should be mentioned somewhere. I’ll bring this up with the team. Thank you again for your input.
I would also agree that it would be reasonable for the OS to handle a full drive, in a much more graceful manner than what you experienced. If this has not already been fixed in 0.4.0, I’ll bring it up in the dev channel.
@freedom How does this info look to you? It’s accurate for today, tomorrow these might change.
This is usually the number you actually want — services cluster into a handful of real-world machines:
Types of Services
Box What’s on it RAM Drive CPU
Files & passwords Vaultwarden, File Browser, Actual Budget, Uptime Kuma, NTFY, etc. 4GB 128–256GB 2-core
Lightning node Bitcoin (pruned) + CLN or LND + RTL/LNbits 16GB 128GB 2–4 core
Bitcoin explorer Bitcoin (unpruned, txindex) + Fulcrum + Mempool (+ Am I Exposed?) 32GB 2TB 4-core
BTCPay merchant Bitcoin + BTCPay (NBXplorer + Postgres) + optional Lightning 16GB 128GB pruned / 2TB archival 4-core
Mining Bitcoin + Datum Gateway or Public Pool 16GB 2TB (Datum, full node) / 128GB (Public Pool, pruned OK) 4-core
Photos/media Immich, or Jellyfin + library 16GB 1TB+ (scales with library) 4-core
Local AI Ollama or llama.cpp + a 7–8B model (+ Open WebUI) 16GB 256GB 4-core, or GPU + 16GB VRAM
Matrix / team chat Synapse or Mattermost 8GB 256GB 2–4 core
Git forge + CI Forgejo/Gitea + its Runner 8GB 256GB+ 4-core
The Bitcoin explorer box at 32GB / 2TB is the demanding one, and it’s the “two of three — fast CPU, fast SSD, 16GB+ RAM” configuration that trips people up; erring high lands it at 32GB for the full indexed stack.
Service by Service
Device = total machine requirement (StartOS base + service + sidecars), err-high, hardware-rounded.
AI
Service Device RAM CPU Drive
llama.cpp 8GB (small) / 16GB (7–8B) / 32GB+ 4-core 256GB (models)
Ollama 8GB (small) / 16GB (7–8B) / 32GB+ 4-core 256GB (models)
Open WebUI 4GB (UI only) 2-core 128GB
vLLM 8GB sys + 16GB VRAM (GPU) / 32GB (CPU) 4-core 256GB+
Bitcoin
Bitcoin Core 8GB pruned-standalone / 16GB serving 4-core 128GB pruned / 2TB unpruned
Bitcoin Knots same as Bitcoin Core 4-core same
Bitcoin Knots (pre-RDTS) same as Bitcoin Core 4-core same
Core Lightning 16GB (incl. required node) 2–4 core 128GB (pruned node)
LND 4GB (Neutrino) / 16GB (with node) 2–4 core 128GB / 2TB
Fulcrum 8GB own → 32GB explorer box 4-core 256GB index → 2TB with node
Datum Gateway 4GB own → 16GB with node 4-core 2TB (full node)
Public Pool 4GB own → 16GB with node 2–4 core 128GB (pruned node OK)
Mempool 16GB own gate → 32GB explorer box 4-core 256GB own → 2TB with node
Alby Hub 4GB 2-core 128GB
BTCPay Server 8GB own → 16GB with node 4-core 128GB pruned / 2TB archival
Lightning Terminal 4GB own → 16GB with LND 2-core 128GB
LNbits 4GB own → 16GB with node 2-core 128GB
Ride The Lightning 4GB own → 16GB with node 2-core 128GB
Robosats 4GB 2-core 128GB
Am I Exposed? 4GB own → 32GB via Mempool stack 2-core 2TB (via Mempool→Bitcoin)
Developer Tools
Forgejo 4GB 2-core 128GB+ (scales w/ repos/LFS)
Forgejo Runner 8GB (w/ Forgejo + jobs), unbounded under load 4-core 256GB+ (image cache, unbounded)
Gitea 4GB 2-core 128GB+ (scales w/ repos/LFS)
Gitea Runner 8GB (w/ Gitea + jobs), unbounded under load 4-core 256GB+ (image cache, unbounded)
Files & Productivity
Cal.diy 8GB 2-core 128GB
DocuSeal 4GB 2-core 256GB+ (scales w/ docs)
File Browser 4GB 2-core scales w/ your data
Garage 4GB 2-core scales w/ stored data
Ghost 8GB 2-core 128GB+
Home Assistant 8GB 2–4 core 128GB+
Mattermost 8GB (x86_64 only) 2-core 128GB+
Nextcloud 8GB 2–4 core 256GB+ / 1TB (scales w/ files)
NTFY 4GB 2-core 128GB
Papra 4GB 2-core 128GB+
SearXNG 4GB 2-core 128GB
Start9 Pages 4GB 2-core 128GB
StartOS Registry 4GB 2-core scales (operator-controlled)
Uptime Kuma 4GB 2-core 128GB
Vaultwarden 4GB 2-core 128GB
Finance
Actual Budget 4GB 2-core 128GB
Spliit 4GB 2-core 128GB
Media
Audiobookshelf 4GB 2-core 256GB+ / 1TB (scales w/ library)
Immich 16GB 4-core 512GB+ / 1TB (scales w/ library)
Jellyfin 8GB 4-core scales w/ media
qBittorrent 4GB 2-core 1TB+ (scales w/ downloads)
Networking
Tor 4GB 2-core 128GB
Nostr
Nostr RS Relay 4GB 2-core 128GB+ (scales w/ events)
Primal 4GB 2-core 128GB
Social
Jitsi Meet 8GB idle / 16GB multi-party 4-core 128GB
OwnTracks Recorder 4GB 2-core 128GB
SimpleX Server 4GB 2-core 128GB
Synapse 8GB 2–4 core 256GB+
