Does anyone have any info on 0.3.6?
In January, some moderator/dev on the forum said, that 0.3.6 is around the corner and about to hit the public testing phase.
Since then I didn’t hear anything again. Does anyone know about the status of 0.3.6?
I want to run a clearnet LND node and at the moment, this is impossible. It will be possible with 0.3.6 apparently.
Cheers
Tennis
From January to April the alpha has been in testing. Lots of work has gone into the new packaging structure… some of that covers clearnet, some of that covers making packaging of services much easier for developers.
The Beta… which is the public testing phase… is expected to be released in the next couple of weeks.
I checked the github repo and tried to get some info after asking.
Seems like the next version is 0.4.0? Or is that already the version after 3.6.0?
It’s a bit hard to follow progress, I guess most devs use forks in private repos.
Glad to here that it is not Tor dependent, I have a 3 week old Pure that I’m setting up and have had trouble with Tor setup. running Knots so far and it is running nicely. Almost have 4 each Bitaxe SupraHex 4.2+ TH/s Bitcoin Miners up and running solo.
Vr,
Lee
