During install selected 2 hd smaller for os larger for data where is my knots node at?
during install selected 2 hd smaller for os, larger for data where is my knots node at?
and drive folder tools for this or way to get to command line to see drives and where knots is installed at?
I’m not sure what you’re asking, your answers appear to be in your very question. When selecting a data drive for data, this places your data on that data drive. That’s where your Knots data is at.
Documentation is found here: https://docs.start9.com/
Setting up SSH will give you CLI access.
I see that same thing I selected a 500GB drive for OS and 2TB for data however my 2TB drive is not mounted and doesn’t seem to be in use.
I have Synced ~70% of the chain and I see this in the stats
is StartOS even using the 2TB drive?
Thanks!!
The above shows the 2TB drive was not selected for the data partition on the selection screen you mention.
Thanks played it safe and am only using the 2tb SSD drive.
