Electrs not starting up correctly
I am running the latest version of Knots(29.3.1) and electrs doesn’t seem to want to connect. Here is the log:
2026-05-30T17:58:21-04:00 Starting electrs 0.11.1 on x86_64 linux with Config { network: Bitcoin, db_path: “./db/bitcoin”, db_log_dir: None, db_parallelism: 1, daemon_auth: UserPass(“bitcoin”, “”), daemon_rpc_addr: 172.18.0.32:8332, daemon_p2p_addr: 172.18.0.32:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, skip_block_download_wait: false, disable_electrum_rpc: false, server_banner: “Welcome to electrs 0.11.1 (Electrum Rust Server)!”, magic: f9beb4d9 }
2026-05-30T17:58:21-04:00 [2026-05-30T21:58:21.522Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
2026-05-30T17:58:21-04:00 [2026-05-30T21:58:21.522Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
2026-05-30T17:58:21-04:00 [2026-05-30T21:58:21.897Z INFO electrs::db] “./db/bitcoin”: 243 SST files, 59.380091072 GB, 7.385003907 Grows
2026-05-30T17:58:23-04:00 [2026-05-30T21:58:23.738Z INFO electrs::chain] loading 939051 headers, tip=000000000000000000009569fad3e780b926565db620017144e694e8b7b63b28
2026-05-30T17:58:25-04:00 [2026-05-30T21:58:25.759Z INFO electrs::chain] chain updated: tip=000000000000000000009569fad3e780b926565db620017144e694e8b7b63b28, height=939051
2026-05-30T17:58:26-04:00 [2026-05-30T21:58:26.013Z INFO electrs::db] closing DB at ./db/bitcoin
2026-05-30T17:58:26-04:00 Error: electrs failed
2026-05-30T17:58:26-04:00 Caused by:
2026-05-30T17:58:26-04:00 0: bitcoind RPC polling failed
2026-05-30T17:58:26-04:00 1: daemon not available
2026-05-30T17:58:26-04:00 2: JSON-RPC error: transport error: unexpected HTTP code: 401
The logs say that Elects can’t reach Bitcoin. Do you know why this would be?
If you just updated, you might trying opening Electr’s config and just hitting save.
I ended up reinstalling it and it’s working now. Thanks.
