Hello, my Electrum server has started restarting constantly and is in a loop.
Start9 is run on Xpenology (Synology) via virtual PC
Any ideas where to look for a problem?
Thanks to
If you have a service in a constant “Starting Loop” the fix for this is usually doing a System Rebuild.
This process can take up to 78 minutes and you will lose connection to your server while it is being done, you will have to be patient and let the server finish and come back online on its own.
No data will be deleted.
You can find this option under System → Power → System Rebuild
Thank you, I tried according to your advice, but I was probably not patient enough and after 3 hours I restarted the server and uninstalled electrs and completely reinstalled electrs.
Electrs is functional again.
I suppose that if I was patient enough, your advice would probably work as well.
Thanks solved
