Hello community,
I would like to ask you for help with EmbassyOS installation. I have my own hw (Intel NUC Kit - NUC7PJYHN). There is only UEFI boot possible, so I can not install EmbassyOS from memory stick.
I had to install Debian and then embassyos_amd64.deb. Installation was successful, but embassyOS has problem - in web browser is error message (please check the enclosed screenshot).
“Deserialization error”
“missing fields os-partitions”
Here is output of /var/log/embassy-init.log.
2022-12-17T19:52:23.008787Z ERROR inner_main{cfg_path=None}: embassy_init: missing field os-partitions
2022-12-17T19:52:23.009349Z DEBUG inner_main{cfg_path=None}: embassy_init: missing field os-partitions
2022-12-17T19:52:25.814643Z ERROR inner_main{cfg_path=None}:init{disk_guid=None error=Error { source:
0: missing field os-partitions
/rustc/a55dd71d5fb0ec5a6a3a9e8c27b2127ba491ce52/library/core/src/convert/mod.rs:550
Backtrace omitted. Run with RUST_BACKTRACE=1 environment variable to display it.
Run with RUST_BACKTRACE=full to include source snippets., kind: Deserialization, revision: None }}: embassy::context::diagnostic: Error: Deserialization Error: missing field os-partitions: Starting diagnostic UI
2022-12-17T19:52:25.814844Z DEBUG inner_main{cfg_path=None}:init{disk_guid=None error=Error { source:
Run with RUST_BACKTRACE=full to include source snippets., kind: Deserialization, revision: None }}: embassy::context::diagnostic: Error { source:
AvahiCallback: ClientState = AVAHI_CLIENT_S_RUNNING
AvahiCallback: EntryGroupState = AVAHI_ENTRY_GROUP_UNCOMMITED
Published “debian.local”
Can anybody help with this issue?
