Feature request - Balance of Satoshi & Telegram bot
Hi guys
I have migrated from a raspibolt setup and features that are quite cool that I would like to see on start9 is channel re-balancing using bos and monitoring your lnd setup with Telegram i.e.:
I hope that would not be too hard to implement?
Have you looked at the different registries? This has been available for a couple of years. It’s worth browsing through the Community registy in particular, lots of gems in there.
The marketplace with the two default registries is accessible from the “Marketplace” menu item inside the StartOS dashboard UI, and those without StartOS can browse it here: https://marketplace.start9.com/ - with the tool to switch registries located under the registry name.
Also worth mentioning that Start9 has no role in deciding on what get packaged for StartOS, nor do we gatekeep to decide what can be run on StartOS. We’re not the developers of individual services listed on the registries, and it’s up to those developers to decide whether they’re interested in releasing their software on StartOS.
Thx StuPleb
I will reach out to Alex Bosworth (the dev of BOS) to enquire anout interest in StartOS as it is not in the marketplace registry yet.
As I’ve said previously, it is in the marketplace and has been there for a very long time. Since 2022.
Balance of Satoshis
This is what I get when cricking the link:
Click the arrows under "Start9 Registry’ it’ll let you change over to the ‘Community Registry’ where you’ll find BoS.
facepalm! Thank you! Got it
