FreeGPT-2 "Starting..."
I installed FreeGPT-2 from the Start9 Marketplace, but under “Services”, I see “Starting …” under Free-GPT-2 but it never turns to “Running” like the other services. I have tried to hit “Stop”, but when I hit “Start”, the same thing starts back up again. I cannot launch the UI.
Anyone know how to go about fixing this?
When a service is in a starting loop, the first check is to make sure that no other service is in this same state, if only FreeGPT-2 is acting like that, then you can do a System Rebuild.
This won’t delete or change anything. Just rebuilds the containers.
You can find this option under System → Power → System Rebuild
Keep in mind that It may take up to a while to complete. During this time, you will not be able to connect to your server, please be patient.
Hi Alvaro,
Thanks for your prompt response. I just did this, but I am still getting the same “Starting…” loop. Any other ideas?
Try uninstalling and reinstalling FreeGPT-2.
I’m in the same position. I just installed Free-GPT and it doesn’t leave the “Starting…” phase. When I check the logs, there is nothing there. I also uninstalled and re-installed it but I’m getting the same result. Is it working for anyone else? I have version 2.01110.0630. And the logs are blank, I have nothing to share on that side.
