Hi, I must have messed something up while learning with Start9OS.
Start9 server runs on Xpenology (Synology) virtual PC.
CPU AMD Athlon 5370, 16GB RAM, 2x SATA disk Btrfs(SHR RAID-backups Start9OS), nvme SSD 2TB,(for Start9OS).
Yesterday, in addition to my native services (bitcoin core + Lighting core + Ride to Lighting GUI, everything worked relatively well so far), I also installed LND and BTCpay server.
Both LND and BTCpay synced for over 10 hours without success.
I did a “System Rebuild” and waited until this morning.
Since then, I have not had access to the system.
I can get to the server’s IP addresses via localhost (ping from the local site is fine within 5ms), but when I enter the password, I get a “Gateway Timeout” error.
I can get into the system via SSH, but I can’t do much there either, just the basics, I don’t know exactly the specifications and commands… (I’m learning).
Below are the screenshots. Finally, I tried to restart Virtual PC, but to no avail.
I didn’t dare to restore Snapshots because of Lighting. (I have open channels and onchain) Please help, how to get out of this, how to restore backups via SSH?
I have backups here: “/volume1/Start9_os_backup”
I don’t have good knowledge of CLI but I’m learning.
Thanks to
#1
Last login: Wed Aug 14 12:54:45 2024 from 192.168.19.13
start9@warmer-snowman:~$ sudo systemctl status
Failed to read server status: Failed to activate service ‘org.freedesktop.systemd1’: timed out (service_start_timeout=2>
lines 1-1/1 (END)
#2
start9@warmer-snowman:~$ ps aux | grep lightningd
start9 40745 0.0 0.0 6856 2008 pts/1 S+ 14:44 0:00 grep lightningd
start9@warmer-snowman:~$ free -h
top
total used free shared buff/cache available
Mem: 11Gi 686Mi 2.6Gi 12Mi 8.7Gi 11Gi
Swap: 2.9Gi 147Mi 2.8Gi
top - 14:51:33 up 5 days, 15:49, 3 users, load average: 0.06, 0.03, 0.00
Tasks: 171 total, 1 running, 170 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 0.2 sy, 0.0 ni, 99.8 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 11955.3 total, 2645.5 free, 689.1 used, 8946.5 buff/cache
MiB Swap: 2988.0 total, 2840.7 free, 147.3 used. 11266.2 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6391 avahi 20 0 7576 3900 3008 S 0.3 0.0 26:49.98 avahi-daemon
40757 start9 20 0 12036 4920 3016 R 0.3 0.0 0:02.35 top
40765 root 20 0 0 0 0 I 0.3 0.0 0:00.08 kworker/0:0-events_freezable_power_
1 root 20 0 168516 5716 4976 S 0.0 0.0 127:50.34 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.81 kthreadd
3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp
5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 slub_flushwq
6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns
10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_wq
11 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread
12 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread
13 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread
14 root 20 0 0 0 0 S 0.0 0.0 7:46.99 ksoftirqd/0
15 root 20 0 0 0 0 I 0.0 0.0 29:31.69 rcu_preempt
16 root rt 0 0 0 0 S 0.0 0.0 0:26.65 migration/0
18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
20 root rt 0 0 0 0 S 0.0 0.0 0:26.80 migration/1
21 root 20 0 0 0 0 S 0.0 0.0 6:50.72 ksoftirqd/1
23 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri
24 root 20 0 0 0 0 S 0.0 0.0 0:00.01 cpuhp/2
25 root rt 0 0 0 0 S 0.0 0.0 0:26.96 migration/2
start9@warmer-snowman:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 5.9G 0 5.9G 0% /dev
tmpfs 1.2G 1012K 1.2G 1% /run
overlay 5.9G 89M 5.8G 2% /
/dev/sda3 15G 3.9G 11G 27% /media/embassy/next
tmpfs 5.9G 84K 5.9G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/sda2 1022M 160M 863M 16% /boot
tmpfs 1.2G 0 1.2G 0% /run/user/1001
/dev/mapper/EMBASSY_N7R6XBOVZASJQKDJKNMMCJA6WHO47HCANT3KQEC3EM5MLNF6QODQ_package-data 1.7T 771G 945G 45% /embassy-data/package-data
/dev/mapper/EMBASSY_N7R6XBOVZASJQKDJKNMMCJA6WHO47HCANT3KQEC3EM5MLNF6QODQ_main 8.0G 1.2G 6.4G 16% /var/log/journal
start9@warmer-snowman:~$ sudo journalctl -b -1
Data from the specified boot (-1) is not available: No such boot ID in journal
start9@warmer-snowman:~$ ps -p 1
PID TTY TIME CMD
1 ? 02:07:50 systemd
start9@warmer-snowman:~$ sudo reboot
Broadcast message from root@start on pts/2 (Wed 2024-08-14 14:53:12 UTC):
The system will reboot now!
Call to Reboot failed: Connection timed out
#3
start9@warmer-snowman:~$ sudo podman ps --all
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
#4 ???
Thanks in advance for your help
