Hi there,
my start9 server pure started making a grinding sound (likely mechanical). I powered it down via the local server interface to prevent further damage. Anyone can advise the safest next steps to diagnose and fix this?
What checks should I perform to determine whether the grinding sound is from a fan vs a drive or RAID disk spin-up?
If it’s likely a failing drive or RAID issue, what is the recommended procedure to identify the failed component and minimize risk to data?
Should I avoid any further power cycles until someone confirm next diagnostics?
Thanks.
