GUI for Personal Node
I have BTC Node up and running in Start9 and I’ve connected my wallet to it using Electrs. Is there some graphical interface service which I can use to view the blockchain as maintained by my own node? Basically something like an online block explorer but relying on my own node rather than someone else’s. Thanks.
Yes! You can self host your own visualizer. Fair warning. This is a heavy service. A low spec machine will struggle with this, and may interrupt other running services if your server is bogged down. Try it out! You can always disable it, when you don’t need it.
