Hello, How do I run lncli ? I have tried
sudo docker exec -it lnd.embassy lncli listchannels
but the command is invalid. thanks
sudo podman exec -it lnd.embassy lncli getinfo
[lncli] rpc error: code = Unavailable desc = connection error: desc = “transport: Error while dialing: dial tcp 127.0.0.1:10009: connect: connection refused”
In the lnd.conf it’s set to:
rpclisten=172.18.0.8:10009
restlisten=172.18.0.7:8080
should I change the IP to 0.0.0.0 or 127.0.0.1 ?
First enter container running:
sudo podman exec -it lnd.embassy bash
then run:
lncli --rpcserver lnd.embassy listchannels
or you can combine them to one command:
sudo podman exec -it lnd.embassy lncli --rpcserver lnd.embassy listchannels
I forgot LND wants the rpcserver flag, thanks H0mer.
