For a newbie how much gb is necessary for a backup of start9 firmware 3.5.1
Firmware has nothing to do with StartOS and isn’t part of any backup you initiate at all.
For simplicity, it makes sense for your backup location to be double the capacity you expect to use, on your server, in the foreseeable future. That way, you don’t have to worry about running out of space just at the wrong time. You can see how much drive capacity your server is currently using under the metrics tab. Keep in mind that blockchain data is not included in the backup.
Thank you both for the reply. The question I had has to do with the recommendation to upgrade to firmware 0.4.2 from 3.5.1 As newbie I am overwhelmed by the actions to be carried out as I read the documentation. Also I am new to Linux and I needed assistence.
You’d update the operating system, not the firmware, and you’d update it to 0.4.0.2 and not 0.4.2.
Backups of your server aren’t specifically related to upgrades or the process of updating StartOS (the operating system). They’re a fallback for when something goes wrong, and you should be backing up your data at all times. Not taking backings leads to a 100% chance of data loss over your lifetime.
Now, should you not have anything worth backing up, that might be completely fine. For example, many users only run a server to run Bitcoin, and for the most part, Bitcoin with standard settings doesn’t need to be backed up (other nodes already contain a copy of the block chain).
The summary of the instructions you find overwhelming is basically:
- uninstall everything you don’t use and don’t need
- update everything else
- make a backup
- hit update StartOS
