How to configure my BTCPay docker install to provide HTTPS certificates?
Hello!
Level: noob
I managed to install Start9OS on my Dell Optiplex 3040.
It was a challenge but due to this guideline (SOS = just can't install StartOS on Optiplex 7040 - systematic "No Bootable Devices found" error - #8 by BlissHodl) I was able to install and run the OS.
As I try to configure the Shopify V2-plugin in the BTCPay Server service/app I encounter this error:
To deploy the Shopify app, you must access your BTCPay Server through a public domain.
In the BTCPay Server document - Dynamic DNS Service I’ve read the following (Dynamic DNS Service | BTCPay Server):
Dynamic DNS is needed if:
  • You need to access your BTCPay Server over internet via HTTPS. (Your BTCPayServer is accessed by other internet users)
So, I created the domain and updated the service in the BTCPay app.
Tough, I have trouble to execute the final step:
Step 3: Configure your BTCPay docker install to provide HTTPS certificates
If you are using a docker deployment, you also need to update your BTCPayServer install. Connect via SSH to your instance and run:
BTCPAY_ADDITIONAL_HOSTS="example.ddns.net"
. btcpay-setup.sh -i
How do I execute this final step?
And foremost, is the above the correct solution for the problem?
Thank you in advance!
StartOS v0.3.5.1 does not have clearnet capabilities and services installed on it can’t have domain names pointed to it until v0.4.0, currently in testing.
Hello,
Thanks for the quick reply.
So that means that for the moment the Shopify V2 Plugin can’t be used?
Are there other solutions/workarounds or do we have to wait until v0.4.0?
Thank you.
I’m not sure if the workaround I posted in the Guides section would work for this, I haven’t tried it.
Hello.
I was working for hours, trying to set up Shopify V2 in the BTCPay server UI, but I cannot get past the step “Deploy the App”, although I inserted a newly generated CLI token. I did understand at some point that the latest version of BTCPay server v. 2.4.0:1 in Start9 OS 0.4.0 doesn´t support this, but a rollback to the earlier version failed due to dependencies towards Core Lightning, I believe it was. I´d really like to be able to set up BTCPay in our webshop and pointing it towards one of our own Lightning servers, LND or CLN. I only tried CLN so far.
I have installed a VPS running StartTunnel and opened the necessary ports for a clearnet connection.
Any help towards this would be greatly appreciated. Maybe someone with a similar setup was able to pull it off already? I´d be curious to know, and I don´t like giving up on things.
Thanks, Teo J in Norway.
On your server’s end, you can check the logs to see if there are any clues. You might also want to update to the very latest BTCPay Server, which got an update a day or two ago
