I need the invoice.macaroon on my Start9 LND hub. Can anyone tell me how I can get the contents of that file? I am able to SSH (over Tor) into my Start9. I can see the Start9 LND setting that lets me “reset the macaroons” but nothing in there lets me view them.
NOTE1: “On startup, lnd checks to see if the admin.macaroon , readonly.macaroon and invoice.macaroon files exist. If they don’t exist, lnd updates its database with a new macaroon ID, generates the three files admin.macaroon , readonly.macaroon and invoice.macaroon , all with the same ID.”
NOTE2: I know how to do it with ThunderHub, but Start9 doesnt’ have Thunderhub (Tools–>Macaroon->Bake)
Is there a trick to getting lncli connect to work? It seems like I am being denied from connecting from within the container.
I tried this, same connect error:
lncli connect <pubkey>@lnd.embassy:9735
netstat -l reports that it allows connections from all hosts to 9735… on that connect call to port 9735 WHY is it giving me an error it cant connect to 10009??
It seems if you need the macaroon you have to transform it like this:
From inside the lnd.embassy container: xxd -ps -u -c 1000 /root/.lnd/public/admin.macaroon
From embassyOS (as root): xxd -ps -u -c 1000 /embassy-data/package-data/volumes/lnd/data/main/public/admin.macaroon
