How to Keep HDMI Display Working After Initial Setup?
Hello, I’m running StartOS on a mini PC and want to manage it exclusively through direct physical access (HDMI monitor + keyboard/mouse) for security reasons. I prefer not to access the web UI from other devices on my network.
What I’m Experiencing
During initial setup, the HDMI kiosk mode works perfectly - I can see the web interface displayed on my connected monitor. However, after setup completes and the system reboots, the HDMI output appears to stop working. The monitor goes dark/shows no signal.
I can still SSH into the system, so StartOS is running fine - just the HDMI display seems to be disabled.
My Questions
1. Is this expected behavior? Does StartOS disable HDMI output after initial setup by design?
2. Is there a way to keep kiosk mode enabled permanently? Either through:
• A setting in the web UI I might have missed?
• A configuration file I can edit via SSH?
• Some other method?
3. Can I access a terminal console on HDMI? Even if the graphical kiosk mode isn’t available, can I get a text console/TTY on the HDMI display (like Ctrl+Alt+F2 on standard Linux)?
4. Is this a hardware issue? My HDMI works fine during setup, and SSH works after, so I assume the hardware is okay - but want to confirm this is a software/configuration issue.
Why I’m Asking
For my threat model, I prefer to manage the node with physical-only access rather than network access (even local network). If there’s a way to keep HDMI working or enable a console on the display, that would be ideal for my setup.
My Setup
• Hardware: Mini PC with HDMI output
• HDMI works perfectly during initial setup (kiosk mode displays fine)
• SSH access works after setup
• HDMI display shows no signal after setup completes
Any help or guidance would be greatly appreciated. Thanks!
Servers are not meant to be accessed this way. The kiosk mode is meant as a troubleshooting tool only. If a monitor is detected during boot-up, kiosk mode loads. If a monitor is not detected, it doesn’t. The kiosk mode involved a browser. Browsers are notorious for excessive resource consumption, and memory leaks. Having kiosk mode running for extended periods of time, will lead to performance, and stability issues.
If your threat model warrants it, a better way to go, would be to setup a dedicated, secure Linux machine for administering your server. This secure machine will be able to access your server via encrypted connection over https, using the certificate generated by your server - no third party certificate authority involved.
