Anyone have any tips or advice on how i can side load fedimint onto my startOS system?
Hi there.
Fediment would first have to be packaged for StartOS. If you’re a dev you could give this a go yourself or you could approach the upstream devs.
You could also try finding a community dev to assist you with packaging a service. You can voice support for it on https://startos.fans/ which could also help it gain more dev attention.
Once packaged, it can be side-loaded
