How do i update my Embassy to the 0.3 OS? I have a Ride the lightning instance that has btc stuck in it. i’m currently running 0.2.17. I’ve seen several topics with the channels getting stuck. Could someone direct me to a form to do the job?
Hi @stonebreaker1080, this will need to be a bit of a DIY approach as there is no longer an upgrade path from 0.2.x. It would be ideal for that reason to start fresh. However, the way to go about recovering the data would be to ssh in and find the path where the LND data is, copy it into the corresponding v0.3.x volume path, then install LND and hope LND will perform the correct migrations on such old data. Hope this helps.
@Jeremy i was able to create a backup for everything. can i just install the new os and restore from backup for ride the lightning?
@Jeremy could you please confirm if i can restore my “ride the lightning” data in the 0.3 OS from the back made in the 0.2 OS?
Here’s the fixed version:
Hi there!
There’s no need to restore RTL from a backup. It’s just an interface to manage your CLN/LND node, and there’s no data besides the configuration that needs to be restored. You can simply install it fresh.
That said, I think restoring from a 0.2 StartOS backup could be an issue because the data structure has changed since then and might not work. You can always try, but I wouldn’t get my hopes up.
