Initial set up connecting to srartlocal securely with Firefox
When I try to set up StartOS and go to start.local#home with Firefox, it is indicated that my connection to this site is Not Secure.
It says, a HTTPs version of start.local is not available. I want to find a way to securely connect with Firefox. How should I do it?
This is correct. You’ll be secure once you’ve imported your certificate. If you believe there are malicious actors on your LAN that might impersonate a Startos server, I’d recommend resolving that much bigger issue before setting up your server. Once you’ve gone through the initial setup, you’ll then be able to connect to your server securely going forward.
Thank you for your response. I was able to go through the initial setup!
