Installing from custom registry after updating to 0.4.1
I used several custom registries for services and now I cannot install any services from these registries. How to trust these services explained simply.
Hi
You would have to ask admins of this registry who host them. If you are asking how to add custom registry then you just go to Marketplce > Choose registry > add
Beginning with StartOS version 0.4.1, to increase security, users are allowed to select who (by their digital signatures) they trust for installation of services and OS.
See: Trusted Keyrings - StartOS
Services are signed by the author / maintainer. You can add the public key of the maintainers you trust to your trusted keyring in StartOS. Then any services they sign will be allowed to be installed. You should be able to reach out to the owners of those custom registries and ask for their help too.
I already read over the trusted keyrings jargon hence the ask to explain simply. Start9 has made it very difficult to obtain software other than their approved software/marketplace. Why can I not click a button “install” or “update” and it work as before for a server that I OWN not contact maintainers nor search endlessly through technical jargon and perform multiple steps I do not want to do?
How can I downgrade the OS 0.4.0 is the next question as restoring my backup only downgrades the services to previous versions not the OS
I’m sorry the trusted keyring jargon is confusing. I’ll try to explain things here and hopefully make it more understandable. The new approach adds a step, and the docs don’t explain it well. I’ve asked Start9 to fix that (#4550). Here’s the plain-English version.
The short answer
Your server now only installs software from people you have approved. Approving someone takes about a minute and only has to be done once. After that, Install and Update work with one click, just like before.
Why it changed
Security - It changed to give you more control over your system. Think of it this way. At the pharmacy, your medicine is sealed and usually with the company’s name printed on it. If the seal is unbroken and has the right name, you know who made it and that nobody tampered with it along the way.
  • A registry is the store.
  • A signature is the seal.
Every package in every registry already has a signature, a seal. A registry won’t accept a package without one, and StartOS won’t install a package without one.
What’s new is that your server now checks whose seal it is. It asks: " Was this seal made by someone I approved? and is it unchanged from when sealed?" If the answer to either is no, it won’t install.
Before, your server trusted the store. Whatever a registry offered, your server installed. If someone broke into a registry, they could slip anything onto your server.
You always control your server
  • You decide whose software runs on your server. The registry doesn’t decide, and neither does Start9.
  • You can approve or remove anyone at any time.
  • Packages on Start9’s own registries are signed by Start9. By default those keys are trusted - but it is your server and you can turn that off and no longer trust the Start9 keys.
There are three ways to load services from a custom registry.
  1. Get the developers public key and add it to your trusted keyrings.
  2. Sideload the service. Download the .s9pk and then use the sideload option.
  3. Use SSH and start-cli command line commands to install the service.
I have added a guide in the Guides section to walk you through the details on each of these three approaches.
Version 0.4.1.2 is now out and it makes this process significantly easier… If you haven’t upgraded yet, I suggest you do so and see for yourself.
I have upgraded to V 0.4.1.2 and am satisfied with the changes. Thank You for all your efforts and assistance in this matter.
