Intel Nuc Start9 Registry not populating
Start9 OS installed fine on a Nuc6i3SYH. The Registry/Marketplace doesnt populate. Can log in to the server via lan fine. Any Ideas as to why no apps populate?
The two registries in the marketplace simply request a massive single batch of data with every single service, their descriptions and details. If your server can’t fetch that data and is blocked from doing so, its more an issue with some aspect of your connection rather than any specific NUC model.
In most cases there’s something with the firewall on the router. In some cases a hard-refresh later on in the day is all that is needed…
Ctrl + Shift + R (Win/Lin)
Cmd + Shift + R (Mac)
I wonder if its due to installing 0.4.0-alpha.11? Yes It was.
Well, there is no v0.4.0 that anyone should be using. So I won’t say much on that, but you clearly found the correct registry.
