Is it possible to install a WebSocket Bridge for Nostr RS Relay?
Since the Damus and Primal apps on iOS do not allow Tor connections to relays, it’s not possible to connect those apps to NOSTR RS Relay on Start9 using the ws://xxxxx.onion address that RS Relay requires.
Is it possible to create a WebSocket Bridge in StartOS?
The steps I’m reading about would require:
  1. Generate a Valid TLS Certificate on Start 9
  2. Install the Certificate on desired device (i.e. iPad or iPhone)
  3. Generate a script to create the Bridge between ws:// and wss://
  4. Run it on StartOS as a service
This code for Step 3 was Ai generated. Before I mess with anything, is this a viable solution to create a wss:// address?
This is a suggested script to use for a Websocket Bridge.
const WebSocket = require('websocket').server;
const TorSocket = require('tor-socket');
const https = require('https');
const fs = require('fs');
// CONFIGURE THESE VALUES
const BRIDGE_PORT = 8443;
const RELAY_ONION = "your-relay-address.onion"; // From Start9 Service Dashboard
const RELAY_PORT = 8080;
const START9_IP = "your-start9-ip"; // e.g., 192.168.1.100
// Load certificate
const server = https.createServer({
  key: fs.readFileSync('/home/embassy/nostr-bridge/certs/bridge.key'),
  cert: fs.readFileSync('/home/embassy/nostr-bridge/certs/bridge.crt')
server.listen(BRIDGE_PORT, () => {
  console.log(`Secure bridge running on wss://${START9_IP}:${BRIDGE_PORT}`);
// Setup WebSocket server
const wsServer = new WebSocket({
  httpServer: server,
  autoAcceptConnections: false
wsServer.on('request', (request) => {
  const connection = request.accept(null, request.origin);
  // Connect to .onion relay via Tor
  const torSocket = new TorSocket({
    host: 'localhost',
    port: 9050, // Start9's Tor port
    destination: {
      host: RELAY_ONION,
      port: RELAY_PORT
  // Handle messages from Damus
  connection.on('message', (message) => {
    if (message.type === 'utf8') {
      torSocket.write(message.utf8Data);
  // Forward relay responses to Damus
  torSocket.on('data', (data) => {
    connection.sendUTF(data.toString());
  connection.on('close', () => {
    torSocket.end();
It appears you’re asking someone to experiment with this for you. It’s probably on you to take the risk, experiment, improve and write up a guide for others.
In my experience, nothing generated from AI is usable without having the knowledge and experience to have created the same thing yourself.
In other news, with the release of v0.4.0 in the near future and its clearnet features, it might make more sense just wait.
I’m not asking for someone to experiment on my behalf. Just to look at the information presented and give advice if it’s viable to proceed at all. If it is, I’ll experiment because that’s how I learn. If it’s not viable, I’ll wait for the release you’ve referenced.
