hi!
i have successfully connected multiple wallets/services to my electrs via tor, at least that’s what the apps say ![]()
is it possible to see it in my electrs log that a connection occurred? i have not found it there yet. maybe i’m blind, stupid or both.
thanks a lot!
You are neither blind or stupid
Electrs does not log incoming connections.
If the app says it’s connected, and it successfully loaded your wallet and shows balance and transactions, you can likely trust that it worked.
I think if you set the log filters to debug, or trace, you’ll see them. Please correct me if I’m wrong. I may be thinking of only failed attempts.
Rexter is right, if you set the logging to ‘Debug’, you can see some activity when something is connecting to it. It’s very verbose and technical. I’d personally just set it to ‘Info’ after you confirmed everything is working correctly for you.
thank you! i will try it out!
appreciate how quickly you were able to help!
edit
on another note, another thing i wasn’t able to find lol:
i’d like to report user cryptoBender. he sent me a mail telling me to get in touch directly with start9 over a link that was obviously a scam. if you need a screenshot, let me know.
it’s been a while since i’ve used a forum, but i must say this here is really well done and designed. i guess just like start9, you could say ![]()
