Is it possible to set up StartOS with multiple ssds?
I’m considering moving to Start9. One of my key considerations is the ability to run multiple disks in raid 1 config. Ideally, I would have one large 2TB ssd for the blockchain and then smaller ssds for lnd data in raid 1 config. Is this setup possible with StartOS?
Hi slaaavo!
The current version of StartOS does not support storing data on separate drives, but this feature is in development for future releases. Your best option is to use a Type 1 hypervisor, like Proxmox, and run StartOS as a VM.
StartOS won’t currently do what you are trying to do there. StartOS stores all service containers, and their data, on a single drive. If you run StartOS in a VM, the virtual drive that StartOS sees as a single drive, can be a Raid 1 handled by the host OS. But you still won’t be able split service between drives. VMs or not.
I have a 128gb SD card and a external 2TB nvme SSD. I flashed the Start9 OS on to the SD card and inserted into my pi 4. During the initial setup the OS was asking which drive to store data so i selected the external nvme SSD. Does this means the OS and the application data will be on the SSD drive?
@S9btc no, since you flashed the OS on the SD card, the OS will be there, while your data will be stored on the external SSD.
Thanks for the reply. So this means future OS updates will be on the SD card right? Also if I install an application will it be on the SD card or the SSD?
OS updates will go to the OS drive/partition. Services are in containers, on the data drive/partition. So in your case, OS updates will go to the SD card. When you install a service, or what you called “an application.” it’s containerized, with it’s corresponding data. This container would be on your external drive.
Let’s take a step back though. We do have a StartOS build for the Raspberry Pi 4. This will make a great little server for lightweight services such as Bitwarden, or Nextcloud. It’s no longer suitable for running a Bitcoin node. The Pi lacks sufficient disk I/O and RAM to handle the ever-growing size of the current UTXO set. The initial block download will be a problem, taking a very long time to complete, if ever. If you transfer a pre-validated blockchain, you can avoid the initial block download issue, and it might work okay for now. But it will be increasingly problematic going forward. For whatever OS you choose to run a Bitcoin node with, ultimately you’re going to need more powerful hardware. Until you do so, I’d probably leave your node as is. Once you have a new node running on more powerful hardware, you can repurpose the Pi for something else using StartOS.
Understand your comments. I am running a pi 4 w/4gb ram running bitcoin core fully synced also with electrs. I am connecting my ledger nano S+ to sparrow wallet which to connected to the private electrum server on my node. So far running on a pi 4 w/4gb ram is smooth. I just SSH into my pi 4.
I have used this hardware RAID successfully with StartOS (Pi4 Embassy), using two SSDs:
I’m running Start9 0.4.0 alpha now. I just finished IBD with Knots and Electrs is fully synced. Now installed FIle Browser but I don’t see any options to select different disks. Is the option just not there? I will try NextCloud next… where will I find options to choose different drives?
I don’t think that’s a feature of 0.4.0. But we’re not supporting 0.4.0 software yet anyway, as it’s still in Alpha. Everything you see there is subject to go away, insult your mother, attack your cat, delete all your stuff, or otherwise change for no apparent reason. Alpha means highly unstable. For experimentation only!
Wow, so blockchain data, lightning data, movie files, pictures, and pdfs just all mix together on one drive? That’s wild.
I was hoping to make a new everything server at home in a single box.
All the servers that Start9 currently sells, which is what StartOS is designed for, have a single drive. But no, not mixed together. All services on StartOS are containerized. More granular control over drive configuration is intended for a future release.
Fair enough. I think I’m going to dive into virtualization, most likely with Proxmox.
That seems to be the solution that most people running home servers are using anyway.
I’m a big fan of the Start9 project. I have two different Dell Optiplex machines running Start9 and have a third one that I’m experimenting with 4.alpha on. The first two are bitcoin stuff only… Knotts, Datum, Electrs, Lightning nodes, etc.
I love the idea of hosting all my own data… fuck “the cloud.” I just think it’s kind of silly to offer these other services like Nextcloud, Jellyfin, and File Browser to all run on a single drive. The next time I post on here it will most likely be with questions related to running Start9 inside Proxmox. :v:
What’s the status of this roadmap item? I am hoping to be able to run Start OS on an SSD and have a separate large HDD to store data for a personal cloud, into which I would symbolic-link the StartOS personal cloud application’s data.
I know this isn’t supported immediately, but I wonder if there is a temporary work-around, specifically by manually mounting the drive and symbolically linking the folder, but I wasn’t able to mount the second drive, so I am suspecting StartOS disables mounting secondary drives.
It’s very low priority right now. Our focus is on getting 0.4.0 shipped. Granular control of a multi-drive setup will not be supported for the foreseeable future. If you hack together a solution, an update to the OS or the service will likely break it. So you’d just have to be prepared to rebuild the setup over, and over again.
I’ve been watching Matt’s videos about AI computing and have become quite excited to connect different purpose driven SSDs to my Start9 while waiting for the WIFI release. This discussion has been going on for a while… Are there any updates or will we be patiently sitting on our hands for a bit longer? Thanks in advance ~
Hoping to find some guidance here… Anyone?
It’s the only real pain point preventing me from switching to S9 for Jellyfin, Navidrome & Immich. All my media is stored on a Synology server and backed up to a second one. I can’t even figure out how to mount network shares in either Filebrowser or Nextcloud, so far. Adding a huge external drive when I already have so much invested in my existing setup isn’t economically feasible or rational, for me. I tried using Hermes to use the guide elsewhere on this site for adding NFS shares to Filebrowser (written for StartOS 0.4.0~beta8) but couldn’t get that working, either. Until there’s a baked-in solution for external storage I won’t be able to fully switch to StartOS. Absolutely love it compared to Synology DSM, otherwise.
