Hi,
I want to start opening a few test Lightning channels using Start9, but had bad experiences with power loss & channel corruption before.
Is Start9 UPS aware? Or is there a guide to installing & running NUT or similar?
Thanks.
Hi,
Thanks.
StartOS is not aware of a UPS if you decide to use one. But it will be a very good idea to use one if you have unstable power at your location.You would have to look for a UPS that will provide enough power for such eventualities.
Maintaining healthy lightning channels does require virtually constant uptime.
Ok Thank-you for the reply. I think I’ll setup Start9 in a VM then.
