Issue : Knots -Datum & Electrs
Hello-
Initially had Bitcoin Core running and then switched to Knots to run Datum but am stuck here-
Trying to setup Datum. Have Knots running, Datum log shows the following:
“Error: The blocknotify field is null or not set in Bitcoin’s configuration. Your Start9 Bitcoin package may not support adding this. Knots is required”
Under Knots - Advanced - Block Notify " curl -s -m5 http://datum.embassy:7152/NOTIFY" as was auto recommend during setup.
Electrs stopped working, it switched between “starting” and “running”, log shows:
bitcoind RPC polling failed, daemon not available, JSON-RPC error: unexpected HTTP code: 401
LND is also unable to start.
Seems need to redirect the RPC?
Thanks in advance
Notification:
install of bitcoind@27.1.0 Failed: Config Generation Error: No Match: blkconstr: Field is Not Nullable
Found Dev tool options and reinstalled all services, and seems to be working now.
